Pump Return, ProtoMAX®
Service Guide
Hypertherm, Inc.
21409 72nd Avenue South
Kent, WA USA 98032
Information:
Technical Support:
E-Mail:
Web:
This document contains subject matter to which OMAX® Corporation has proprietary rights. Recipients of this document shall not duplicate, use, or disclose information contained herein, in whole or in part, for any use other than the purpose for which this manual was provided.
Hypertherm, Inc.
Technical Publications
Kent, WA, USA 98032
Hypertherm, Inc. is continually improving their equipment to bring you the best in abrasive waterjet machining technology. For that reason, your abrasive waterjet may differ slightly from what is described in this document. If you have any questions, please feel free to contact us at 1-800-298-4036 or e-mail us at info@protomax.com. You can also receive technical support on-line at: Web: http://www.omax.com/protomax-waterjet.
November 2019
© 2019 Hypertherm, Inc.
Important Safety Information
SAFETY IS YOUR RESPONSIBILITY.
For your own safety, read this guide thoroughly and carefully before the equipment is installed, operated, maintained, or issues are troubleshooted.
Save these instructions.
This guide contains important safety information for the equipment. Careful compliance with the safety information helps prevent physical injury, damage to the equipment, and can extend the equipment's life.
Equipment safety features, safety glasses, hearing protection, and more can reduce potential injury. Be careful when the equipment is installed, operated, and maintained. Safety guards and features do not guarantee your safety if you are careless, inattentive, or use poor judgment. If it feels dangerous, do not try it.
YOU ARE RESPONSIBLE FOR YOUR SAFETY IN YOUR SHOP.
Machine Safety Labels
WARNING Electrical Shock
WARNING Airborne Debris
WARNING Pinch Risk
Electrostatic Discharge
No Open Flame
Do Not Spray
Do Not Step
Read Manual
Wear Hearing Protection
Wear Eye Protection
Wear Gloves
Safety Precautions
Safety instructions must be followed when the equipment is installed, operated, or maintained. If ignored, death or physical injury can result, or damage can occur to the equipment. Always follow the applicable safety precautions when work is done with this equipment.
Use the equipment ONLY for its intended function
  • Read the installation manual before the equipment is set up to learn about important installation and safety information.
  • Read the documentation for recommended accessories. The use of incorrect accessories can cause a risk of injury to persons or damage to equipment.
  • Wear eye and hearing protection. Always wear ISO-approved impact safety glasses.
  • Make sure the equipment is installed correctly before the system is started.
  • Never stand on the equipment. Serious injury can occur if the machine tips or you touch the machining tool during operation.
Do not make changes
  • Do not make changes to the equipment or components that are not approved.
  • Changes to the equipment can cause a risk of physical injury to the operator and others and can cause damage to the equipment or other property. Changes to the equipment will void the warranty.
  • Do not change, defeat, or bypass the equipment safety features.
Do not remove panels
  • Do not remove the panels during operation. Only remove them when required by maintenance or to troubleshoot problems.
Check for damaged parts
  • Before the equipment is used, carefully examine guards or other parts that are damaged to make sure that it operates correctly and functions as intended. Examine to make sure parts that move, move freely, are aligned correctly, are not broken, are mounted correctly, and for other conditions that can have an effect on its operation. Replace guards or other damaged parts.
Use caution, stay alert, and be attentive
  • Do not install, operate, or service the equipment while under the influence of alcohol or drugs. Read the warning labels on prescription and over-the-counter drugs. If in doubt, do not install or operate the machine.
  • Do not install, operate, or service the equipment when you are tired.
  • Always follow the safety precautions when the equipment is installed, operated, maintained, or serviced. Carefully operated, the abrasive waterjet is a safe tool. When operated carelessly, serious injury can result.
  • Wear a face or dust mask.
  • Do not reach over the machine to operate it. Keep feet on the floor and balanced at all times.
  • Keep a minimum of 16 in. (40 cm) away from pressurized equipment during operation.
  • Do not try to tighten the ultra high-pressure (UHP) fittings when the system is pressurized.
Keep the tools and equipment in good condition
  • Keep machine and accessories clean for the best and safest performance.
  • Always keep the equipment in good condition.
  • Follow the maintenance instructions for equipment and accessories.
  • Keep all protective guards and stop devices.
Keep the equipment and area around the equipment clean and free from clutter
  • Remove all installation, operation, or maintenance tools from the equipment before it is operated.
  • Keep the work area clean and clutter-free to prevent accidents.
  • Keep the equipment clean for the best performance.
Do not operate the equipment in a dangerous environment
  • Do not use the equipment in or around flammable gases or liquids.
  • Do not expose the equipment to rain or use it outdoors.
  • Keep the equipment in a bright work area.
Never leave the equipment unattended during operation
  • Always stop and turn off the equipment before leaving the area.
  • Keep visitors at a safe distance from the work area.
  • Keep children away from the equipment work area.
  • Do not let children play around or operate the equipment or its components.
Never operate the equipment without safety guards or covers
  • Do not change, bypass, or try to defeat the safety guards, covers, or switches.
  • Keep the guards in position and in working order.
  • Do not remove the safety cover or guard during operation.
  • Know the location of the ON/OFF switch.
  • Know how to disconnect the primary power supply to the equipment.
  • Start and operate the machine only when all side panels are in position.
Never put your hands in the area of the nozzle during operation
  • Seek immediate medical aid for all waterjet injuries. Injuries caused by high-pressure abrasive waterjets are serious. Do not wait!
  • Refer to the WaterJet Technology Association (WJTA) warning card for important medical aid information.
Figure 1
Be careful when material(s) is moved in the catcher tank
  • Do not operate the equipment when material is moved into the catcher tank.
  • Always stop the abrasive waterjet before adjustments are made to the material or the abrasive jet.
  • Always be careful when material is moved into the catcher tank. Fingers can be caught between a heavy part and the support slats.
  • Be careful around the support slats. The abrasive waterjet also cuts the support slats; the edges can become sharp and cause cuts or collapse.
  • Always use a licensed electrician or approved person to install the primary power source to use with the machine.
  • Examine the equipment power and control cables regularly for correct connection and installation. Damaged, exposed, and bare wires can cause electrocution or death!
  • Make sure the equipment is correctly connected and grounded in accordance with the national, state, and local codes. Do not remove the prongs from the plug. Always plug into the correct electrical outlet.
  • Never use any electrical plug adapter.
  • Make sure the power switch is in the OFF position before the equipment is plugged in to stop accidental starts.
  • Always disconnect the equipment from the primary power before service or maintenance work is done.
Noise Emission Precautions
Environmental factors, such as how the room or structure is built, other machines and power tools in the area, and other noise sources, can have an effect on the environment's true noise level. When installed and operated correctly, the equipment's A-weighted emission sound pressure level, LpA , is less than 75 dBA (LpA < 75 dBA). Therefore, OMAX recommends that the operator wear hearing protection during equipment operation.
Injuries that involve contact with the catcher tank water should receive medical aid immediately. Refer to the WJTA Warning Card for important medical aid information.
Get medical aid immediately for an abrasive waterjet injury. Tell the physician the cause of the injury, the type of abrasive waterjet work that was done when the accident happened, and the water source.
Stagnant water in the catcher tank can introduce dangerous bacteria into cuts, scrapes, small breaks in the skin, and other types of wounds. Injuries that involve contact with the catcher tank water should receive aid immediately. Injuries that involve contact with the water should be attended to immediately.
Unusual infections with aerophilic microorganisms that occur at lower temperatures have been reported. These can be gram-negative pathogens, such as those found in sewage. Bacterial swabs and blood cultures may be helpful to assist a physician's diagnosis.
An injury caused by high-pressure waterjets can be dangerous. If there is a waterjet injury:
  • Get medical aid immediately. Do not wait!
  • Tell the physician of the cause of the injury.
  • Tell the physician about the type of abrasive waterjet work done when the accident happened and the water source.
  • Give this information to medical personnel:
    This patient may be suffering from a waterjet injury. Evaluation and management should parallel that of a gunshot injury. The external manifestations of the injury cannot be used to predict the extent of internal damage. Initial management should include stabilization and a thorough neurovascular examination. X-rays can be used to assess subcutaneous air and foreign bodies distant from the site of injury. Injuries to the extremities can involve extensive nerve, muscle, vessel damage, and cause a distal compartment syndrome. Injuries to the torso can involve internal organ damage. Surgical consultation should be obtained. Aggressive irrigation and debridement is recommended. Surgical decompression and exploration may also be necessary. Angiographic studies are recommended pre-operatively if arterial injury is suspected. Bandages with a hygroscopic solution (MgSO4) and hyperbaric oxygen treatment have been used as adjunctive therapy to decrease pain, edema, and subcutaneous emphysema. Unusual infections with uncommon organisms in immunocompetent patients have been seen; the source of the water is important in deciding on initial, empiric antibiotic treatment, and broad-spectrum intravenous antibiotics should be administered. Cultures should be obtained.
Lockout/Tagout
Do standard practices and procedures to shutdown and stop the equipment, isolate it from its energy source(s), and prevent the release of potentially dangerous energy when maintenance and service work is done.
  • Make sure the equipment is correctly grounded in accordance with the national, state, and local codes. Do not remove the prongs from the plug. Always plug into the correct electrical outlet.
  • The ground wire gives the electric current a path of least resistance to reduce the risk of electrical shock during a malfunction or breakdown. The machine has an electric cord with an equipment-grounding conductor (EGC) and a ground plug (United States, Canada, and Mexico only). The plug must be connected to a matching outlet that is correctly installed and grounded in accordance with all local codes and ordinances.
  • Do not change the plug—if it does not fit the outlet, have the correct outlet installed by a qualified electrician.
  • If the EGC is incorrectly connected, it can result in electric shock.
  • Contact a qualified electrician or service personnel if the grounding instructions are not understood or if not sure if the equipment is correctly grounded.
  • Do not use extension cords with the equipment.
  • If the cord is damaged or worn, immediately replace it. Contact OMAX for replacement parts and instructions. The insulation of the EGC is covered with a green or green with yellow-striped surface. If replacement of the electric cord or plug is necessary, do not connect the equipment-grounding conductor to a live terminal. Refer to the equipment-specific wiring configuration.
  • The equipment is intended to be used on a circuit with an outlet similar to the one shown (United States, Canada, and Mexico only):
Figure 2
  • The grounding plug is similar to the one shown (United States, Canada and Mexico only):
Figure 3
  • Make sure that the equipment is connected to an outlet that matches the plug configuration.
  • The equipment must not be connected to any different type of electric circuit.
  • No adapter is available or should be used with this equipment.
  • For countries other than the United States, Canada, and Mexico, OMAX does not supply a sufficiently rated industrial-grade plug.
  • Contact a qualified electrician or service personnel to install a sufficiently rated industrial-grade plug in accordance with national, state, and local codes.
  • A pin and sleeve plug, rated at least 30A, 230V, 2-pole+E (3-wire grounding), IP44 or better, having a first-make last-break protective bonding contact (earthing contact) in accordance with standards IEC 60309-1 and IEC60309-2 can fulfill this requirement.
Figure 4
  • The cord must be plugged into a matching outlet that is correctly installed and grounded in accordance with all local codes and ordinances.
Figure 5
Machining certain types of material, such as titanium, with a waterjet can cause sparks. Do not operate the equipment in an explosive environment. Do not let explosive or flammable vapors collect in the area of the equipment.
Removal of Waste Materials
Discard all machining wastes correctly in accordance with all local and federal regulations. Abrasive waterjet machining causes two types of waste: the water used for machining and the solid material that collects in the catcher tank. Although the used garnet abrasive is not dangerous, the waste deposited from the cut material can require special treatment.
Sufficient Shop Ventilation
Make sure there is good airflow in the work area to dissipate gases, vapors, and fumes. The machine contains a large amount of water. The ambient temperature in the shop and of the water can have an effect on water evaporation. To decrease the effect on other equipment in the shop, make sure there is good airflow in the shop. Also, some materials, such as aluminum particles, are known to make hydrogen in water.
When aluminum is cut, the small particles of aluminum dust in the catcher tank react with the water to make flammable hydrogen gases. Usually, hydrogen bubbles to the surface and is released into the shop in safe, low concentrations.
Make sure no ignition sources (open flame or electrostatic discharge) are near the abrasive waterjet system.
Monitor the catcher tank for hydrogen gas bubbles when large quantities of aluminum are cut. The aluminum powder (made from the removed material) and spent garnet collect at the bottom of the catcher tank. The aluminum then reacts with the water and releases hydrogen gas. The hydrogen gas can collect in bubbles in the garnet. The hydrogen gas bubbles are flammable. Keep the garnet levels in the catcher tank low to prevent hydrogen gas bubbles from being collected within the garnet.
Do not smoke near the machine. Keep other sources of ignition or flammable materials near the machine. Be careful when materials that create sparks are cut, such as titanium, which can fire the gases in the catcher tank and cause an explosion. Remove the aluminum powder from the catcher tank before machining materials that spark.
Equipment Safety Features
The abrasive waterjet has several built-in safety features:
Overpressure Protection
During operation, pump pressure is monitored to prevent an overpressure condition. If the pump pressure increases more than the factory-set maximum pressure limit, the safety relief valve starts and stops the pump.
Electrical Protection
An electrical disconnect/emergency machine off (EMO) switch is used to remove the primary AC electrical supply from the machine. To isolate the machine from its electrical supply, always unplug the primary AC supply power cord from its electrical supply outlet.
Safety Lid
The lid of the equipment has a safety interlock to prevent waterjet operation when the lid is open.
Safety Legend
WARNING
CAUTION
NOTICE
Note
REQUIRED TOOLS
The following table contains a list of tools with the appropriate sizes needed to set up the ProtoMAX pump.
Customer Provided Tools
These tools are not provided by OMAX or included with the ProtoMAX pump.
Icon Tool Size(s)
Safety gloves
Safety glasses
Utility knife
Scissors
Pry bar
Socket wrench
Socket 7/16 in.
Ball-end hex wrench 4 mm, 5 mm
Open-end wrench 10 mm, 17 mm
OMAX Provided Tools
These tools are included with the ProtoMAX pump.
Icon Tool Size(s)
Pump crate
(P/N 209203)
Packing straps/clips
REFERENCES
Documents
The following table contains documents associated with these instructions.
Part Number Title
401420 Installation, ProtoMAX
401434 Operation, ProtoMAX
401440 Maintenance, ProtoMAX
Videos
Videos associated with these instructions are located at protomax.com.
DOCUMENT SCOPE
This document contains instructions for unpacking a new ProtoMAX pump and sending the original pump back to OMAX.
UNPACK THE NEW PUMP
Caution
The ProtoMAX pump weighs approximately 175 lbs (79 Kg). To avoid injury, clear the area of obstacles and debris before installation. Two or more people are recommended to move the ProtoMAX pump. Always move the pump slowly to prevent injury or damage.
1. Place the pump crate near the installation location.
2. Remove the plastic sheeting and shipping bands from the box and discard.
Warning
SUFFOCATION RISK! Plastic sheeting can be dangerous. Thin plastic film may cling to the nose and mouth preventing breathing. Keep the plastic bag away from babies, small children, and pets.
Caution
Plastic sheeting may be slippery. Once the plastic sheeting is removed from the ProtoMAX pump, remove it from the area to avoid slip, trip, and/or fall injuries.
3. Carefully remove the shipping crate top and sides, and set aside.
Figure 6
NOTE
Reuse the crate and shipping materials to pack and ship the original pump.
4. Remove the lag bolts securing the pump to the crate and set aside.
Figure 7
NOTE
The pump may be moved for easier access to the side bolts.
5. Remove the pump side bolts [1] and brackets [2], then set aside.
Figure 8
Caution
Two people are recommended to move the pump. Always move the pump slowly to avoid injury.
Notice
Do not tilt the pump on the side. Tilting the pump may damage the caster brackets. Roll or lift the pump by its frame when moving to avoid damage.
6. Unlock the pump wheels and lift the pump from the crate.
Figure 9
7. Remove the crank case cover [1] screw, then set aside.
Figure 10
8. Turn the pump around, loosen the front cover captive screws, then remove the front cover [1] and the crankcase cover.
Figure 11
9. Remove the red plug [1] from the oil filler port and set aside for returning the original pump.
Figure 12
10. Retrieve the dip stick from the wrapper taped to the wet end of the pump.
11. Insert the dip stick [1] to the oil filler port [2].
Figure 13
12. Replace the front cover and crankcase cover.
REMOVE THE ORIGINAL PUMP
CAUTION
Prior to performing any service, ensure the air supply to the system is turned OFF and the entire pneumatic system is exhausted including any accessories. Failure to release pressure may result in injury.
1. Turn ProtoMAX OFF.
2. Disconnect all lines to the original pump. See 401440 Maintenance, ProtoMAX.
3. Remove the original pump from the machine, then set aside. See 401440 Maintenance, ProtoMAX.
4. After the new pump is installed, prepare the original pump for return. See Prepare the Original Pump for Return.
Notice
If the original pump is leaking oil, drain the oil prior to preparing for return. Shipping services may refuse shipment if oil is leaking from the pump.
INSTALL THE NEW PUMP
1. Connect the new pump to the ProtoMAX. See 401420 Installation, ProtoMAX.
2. Test the new pump and check for leaks. See 401434 Operation, ProtoMAX.
PREPARE THE ORIGINAL PUMP FOR RETURN
Caution
1. Remove the crank case cover [1] screw, then set aside.
Figure 14
2. Turn the pump around, loosen the front cover [1] captive screws, then remove the front cover and the crankcase cover.
Figure 15
3. Remove the dip stick [1] from the oil filler port [2].
Figure 16
4. Retrieve the red plug [1] from the new pump, then screw it to the oil filler port.
Figure 17
NOTE
Oil may leak from the oil filler port during shipment if the dip stick is not replaced with the red plug. Shipping services may refuse shipment if oil is leaking from the pump.
5. Replace the front cover and crankcase cover.
6. Mark the location of the lag bolt holes on the crate floor.
NOTE
To prevent the pump from moving during shipment, do not position the brackets in the same place as received. Load the original pump in the opposite direction as the new pump was loaded so the lag bolts are drilled on fresh wood. No predrilling is required.
Notice
Do not lift the pump by the safety valve or wet end. Roll or lift the pump by its frame when moving to avoid damage.
Figure 18
7. Lock the pump wheels, then load the pump to the crate.
8. Loosely install the side bolts [1] and brackets [2] to the side of the pump.
Figure 19
9. Install the lag bolts to secure the pump to the crate.
Figure 20
10. Tighten the side bolts [1] and brackets [2].
Figure 21
11. Replace the crate sides.
12. Place a copy of the emailed RMA packing slip inside the crate, then replace the crate top.
13. Enclose the crate with the shipping box, then secure the box using the provided packing straps and metal buckles.
NOTE
To secure the box to the crate, loop the straps through the metal buckles, then pull to tighten.
Figure 22
14. Write the RMA number on the box.
RETURN THE ORIGINAL PUMP
When the original pump is ready for shipping, notify OMAX at omax.shipping@omax.com for the next steps.
Provide the following information in the email.
  • Business name and name of person reporting
  • Address
  • Phone number
  • Email address
TECHNICAL SUPPORT
Refer to www.omax.com/service-support for technical support contact information.
