REMOVE THE ORIGINAL PUMP
CAUTION
Prior to performing any service, ensure the air supply to the system is turned OFF and the entire pneumatic system is exhausted including any accessories. Failure to release pressure may result in injury.
| 1. | Turn ProtoMAX OFF. |
| 2. | Disconnect all lines to the original pump. See 401440 Maintenance, ProtoMAX. |
| 3. | Remove the original pump from the machine, then set aside. See 401440 Maintenance, ProtoMAX. |
| 4. | After the new pump is installed, prepare the original pump for return. See Prepare the Original Pump for Return. |
Notice
If the original pump is leaking oil, drain the oil prior to preparing for return. Shipping services may refuse shipment if oil is leaking from the pump.
