ProtoMAX®
Drain Water Filter Tank Guide
Assemble the Drain Water Filter Tank
Hypertherm, Inc.
21409 72nd Avenue South
Kent, WA USA 98032
Information:
Technical Support:
E-Mail:
Web:
info@protomax.com
1-800-298-4036
support@protomax.com
www.omax.com/protomax-waterjet
This document contains subject matter to which Hypertherm, Inc. has proprietary rights. Recipients of this document shall not duplicate, use, or disclose information contained herein, in whole or in part, for any use other than the purpose for which this manual was provided.
Hypertherm, Inc.
Technical Publications
Kent, WA, USA 98032
Hypertherm, Inc. is continually improving their equipment to bring you the best in abrasive waterjet machining technology. For that reason, your abrasive waterjet may differ slightly from what is described in this document. If you have any questions, please feel free to contact us at 1-800-298-4036 or e-mail us at info@protomax.com. You can also receive technical support on-line at: Web: http://www.omax.com/protomax-waterjet.
April 2018
© 2018 Hypertherm, Inc.
Machine Safety Labels
WARNING Electrical Shock
WARNING Airborne Debris
WARNING Pinch Risk
Electrostatic Discharge
No Open Flame
Do Not Spray
Do Not Step
Read Manual
Wear Hearing Protection
Wear Eye Protection
Wear Gloves
Safety Legend
WARNING
CAUTION
NOTICE
Note
Required Tools
The following table contains a list of tools with the appropriate sizes that are needed to install and maintain the Drain Water Filter Tank. Tools listed with part numbers are included with the ProtoMAX.
Icon Tool Size(s)
Ratchet shears
Safety glasses
Gloves, latex
Components
Figure 1
[1] Tank [2] 90 degree elbow [3] Tank cover [4] Filter bag [5] Pump assembly
Unpack the Drain Water Filter Tank
1. Remove the drain water filter tank and components from the box.
caution
Use care when removing the packaging materials from the electrical cords. Do not use sharp objects to remove the packing material. Sharp objects can puncture the electrical cord and create a shocking hazard.
2. Remove the packaging materials from the components and power cords.
caution
1. Place the drain water filter tank [2] approximately 12 in. (30 cm) from the right rear corner of the machine [1].
Figure 2
2. Place the pump assembly [1] in the tank [2].
Figure 3
3. Place the tank cover [2] on the tank, routing the cables and hose through the slot [1].
Figure 4
4. Place the filter bag through the center hole, ensuring the filter lip [1] sits on the top of the cover.
Figure 5
5. Expand the filter bag sides.
6. Measure and cut the catcher tank drain water hose [1] so it reaches to approximately the middle of the tank cover, if applicable.
Figure 6
7. Place the 90-degree elbow [2] on the catcher tank drain hose [1] , then place the hose assembly in the center of the filter bag; secure the hose with the filter bag strap if needed.
note
To avoid clogging the drain hose or overflowing the tank, ensure the 90-degree elbow is placed in the center of the drain tank cover and there are no bends, kinks, or sags along the catcher tank drain hose.
Figure 7
8. Route the drain water filter tank hose to the drain.
9. Plug the pump power cord [2] into the float switch power connection [1].
Figure 8
caution
Ensure the equipment is properly grounded in accordance with national, state, and local codes. Never remove any prong from the plug. Always plug into the proper electrical outlet. See the Safety section for important grounding information. Improper connection can result in a risk of electrical shock. If the electrical outlet is NOT properly grounded, or if in doubt as to whether the tool is properly grounded, contact a qualified electrician or service personnel.
10. Connect the pump and float switch to the power source.
Operate the Drain Water Filter Tank
The Drain Water Filter Tank is an easy, mess-free option for disposing the machining debris. The drain water contains garnet abrasive and cutting particles (aluminum, wood, etc.) that will plug sewer lines. The drain water filter tank captures machining debris (for easy disposal) and allows filtered water to flow to the drain. Once installed, the drain water filter tank system operates automatically and only requires monitoring and periodic maintenance to ensure continuous operation. See the Important Safety Information, Disposing of Waste Materials section for additional information.
Replace the Filter Bag
caution
Bacteria in the tank water can build up. A minor break in the skin can introduce harmful bacteria into a wound. Always wear protective gloves if you have cuts or open wounds on your hands. Wear gloves that provide protection against sharp metal edges.
caution
The garnet abrasive is not a chemical irritant, but if not quickly washed out, it can injure an eye just as sand would. In addition, tank water could contain particles from the material or chemical irritants. Always wear eye protection when working on the ProtoMAX.
caution
Spent garnet and catcher tank material can be heavy. Use care when lifting drain water filter bag to prevent injury.
notice
The filter bag will seep and/or drain excess water when placed on the ground. Always place the filter bag in a waterproof container or bag to avoid damage to the floor and surrounding area.
1. Unplug the pump and float switch from the power source.
2. Compress the filter bag lip and remove the tank cover.
Figure 9
3. Place the catcher tank drain hose in the drain water filter tank.
Figure 10
4. Lift the filter bag from the tank and place it in a water proof container.
5. Gently tap the filter bag to dewater.
6. Discard the old filter bag, see Important Safety Information for Disposing of Waste Materials.
7. Remove sediment from the tank and clean the tank and components, see Clean the Drain Water Filter Tank.
1. Unplug the pump assembly from the power source.
2. Remove the pump assembly [1] from the tank.
Figure 11
3. Remove the sediment from the tank.
4. Spray the pump assembly with a strong stream of water to remove all sediment.
5. Remove the suction cover [1] and spray with a stream of water to remove all sediment.
Figure 12
6. Reinstall the suction cover [1] on the pump (Figure 12).
7. Reassemble the drain water filter tank, see Assemble the Drain Water Filter Tank.
Technical Support
Refer to the OMAX website for technical support contact information.
Warranty
Contact Customer Support or go to the ProtoMAX website.
