Assemble the Drain Water Filter Tank
Use care when removing the packaging materials from the electrical cords. Do not use sharp objects to remove the packing material. Sharp objects can puncture the electrical cord and create a shocking hazard.
| 1. | Place the drain water filter tank [2] approximately 12 in. (30 cm) from the right rear corner of the machine [1]. |
Figure 2
| 2. | Place the pump assembly [1] in the tank [2]. |
Figure 3
| 3. | Place the tank cover [2] on the tank, routing the cables and hose through the slot [1]. |
Figure 4
| 4. | Place the filter bag through the center hole, ensuring the filter lip [1] sits on the top of the cover. |
Figure 5
| 5. | Expand the filter bag sides. |
| 6. | Measure and cut the catcher tank drain water hose [1] so it reaches to approximately the middle of the tank cover, if applicable. |
Figure 6
| 7. | Place the 90-degree elbow [2] on the catcher tank drain hose [1] , then place the hose assembly in the center of the filter bag; secure the hose with the filter bag strap if needed. |
To avoid clogging the drain hose or overflowing the tank, ensure the 90-degree elbow is placed in the center of the drain tank cover and there are no bends, kinks, or sags along the catcher tank drain hose.
Figure 7
| 8. | Route the drain water filter tank hose to the drain. |
| 9. | Plug the pump power cord [2] into the float switch power connection [1]. |
Figure 8
Ensure the equipment is properly grounded in accordance with national, state, and local codes. Never remove any prong from the plug. Always plug into the proper electrical outlet. See the Safety section for important grounding information. Improper connection can result in a risk of electrical shock. If the electrical outlet is NOT properly grounded, or if in doubt as to whether the tool is properly grounded, contact a qualified electrician or service personnel.
| 10. | Connect the pump and float switch to the power source. |
