Clean the Drain Water Filter Tank
| 1. | Unplug the pump assembly from the power source. |
| 2. | Remove the pump assembly [1] from the tank. |
Figure 11
| 3. | Remove the sediment from the tank. |
| 4. | Spray the pump assembly with a strong stream of water to remove all sediment. |
| 5. | Remove the suction cover [1] and spray with a stream of water to remove all sediment. |
| 6. | Reinstall the suction cover [1] on the pump (Figure 12). |
| 7. | Reassemble the drain water filter tank, see Assemble the Drain Water Filter Tank. |
