Correct Safety Valve Water Leaks
The following identifies the source of possible water leaks in the safety valve and how to correct them.
Figure 721
| Leak | Leak Description | Suspected Cause | Recommended Action |
| [1] | Leak from safety valve body weep holes | Seat to ceramic ball failure | Replace the Safety Valve |
| [2] | Leak from T-fitting weep holes | Seat failure | Replace the Safety Valve |
