ProtoMAX®
Maintenance, Storage
Hypertherm, Inc.
21409 72nd Avenue South
Kent, WA USA 98032
Information:
Technical Support:
E-Mail:
Web:
This document contains subject matter to which OMAX® Corporation has proprietary rights. Recipients of this document shall not duplicate, use, or disclose information contained herein, in whole or in part, for any use other than the purpose for which this manual was provided.
Hypertherm, Inc.
Technical Publications
Kent, WA, USA 98032
Hypertherm, Inc. is continually improving their equipment to bring you the best in abrasive waterjet machining technology. For that reason, your abrasive waterjet may differ slightly from what is described in this document. If you have any questions, please feel free to contact us at 1-800-298-4036 or e-mail us at info@protomax.com. You can also receive technical support on-line at: Web: http://www.omax.com/protomax-waterjet.
September 2019
© 2019 Hypertherm, Inc.
Important Safety Information
SAFETY IS YOUR RESPONSIBILITY.
For your own safety, read this guide thoroughly and carefully before the equipment is installed, operated, maintained, or issues are troubleshooted.
Save these instructions.
This guide contains important safety information for the equipment. Careful compliance with the safety information helps prevent physical injury, damage to the equipment, and can extend the equipment's life.
Equipment safety features, safety glasses, hearing protection, and more can reduce potential injury. Be careful when the equipment is installed, operated, and maintained. Safety guards and features do not guarantee your safety if you are careless, inattentive, or use poor judgment. If it feels dangerous, do not try it.
YOU ARE RESPONSIBLE FOR YOUR SAFETY IN YOUR SHOP.
Machine Safety Labels
WARNING Electrical Shock
WARNING Airborne Debris
WARNING Pinch Risk
Electrostatic Discharge
No Open Flame
Do Not Spray
Do Not Step
Read Manual
Wear Hearing Protection
Wear Eye Protection
Wear Gloves
Safety Precautions
Safety instructions must be followed when the equipment is installed, operated, or maintained. If ignored, death or physical injury can result, or damage can occur to the equipment. Always follow the applicable safety precautions when work is done with this equipment.
Use the equipment ONLY for its intended function
  • Read the installation manual before the equipment is set up to learn about important installation and safety information.
  • Read the documentation for recommended accessories. The use of incorrect accessories can cause a risk of injury to persons or damage to equipment.
  • Wear eye and hearing protection. Always wear ISO-approved impact safety glasses.
  • Make sure the equipment is installed correctly before the system is started.
  • Never stand on the equipment. Serious injury can occur if the machine tips or you touch the machining tool during operation.
Do not make changes
  • Do not make changes to the equipment or components that are not approved.
  • Changes to the equipment can cause a risk of physical injury to the operator and others and can cause damage to the equipment or other property. Changes to the equipment will void the warranty.
  • Do not change, defeat, or bypass the equipment safety features.
Do not remove panels
  • Do not remove the panels during operation. Only remove them when required by maintenance or to troubleshoot problems.
Check for damaged parts
  • Before the equipment is used, carefully examine guards or other parts that are damaged to make sure that it operates correctly and functions as intended. Examine to make sure parts that move, move freely, are aligned correctly, are not broken, are mounted correctly, and for other conditions that can have an effect on its operation. Replace guards or other damaged parts.
Use caution, stay alert, and be attentive
  • Do not install, operate, or service the equipment while under the influence of alcohol or drugs. Read the warning labels on prescription and over-the-counter drugs. If in doubt, do not install or operate the machine.
  • Do not install, operate, or service the equipment when you are tired.
  • Always follow the safety precautions when the equipment is installed, operated, maintained, or serviced. Carefully operated, the abrasive waterjet is a safe tool. When operated carelessly, serious injury can result.
  • Wear a face or dust mask.
  • Do not reach over the machine to operate it. Keep feet on the floor and balanced at all times.
  • Keep a minimum of 16 in. (40 cm) away from pressurized equipment during operation.
  • Do not try to tighten the ultra high-pressure (UHP) fittings when the system is pressurized.
Keep the tools and equipment in good condition
  • Keep machine and accessories clean for the best and safest performance.
  • Always keep the equipment in good condition.
  • Follow the maintenance instructions for equipment and accessories.
  • Keep all protective guards and stop devices.
Keep the equipment and area around the equipment clean and free from clutter
  • Remove all installation, operation, or maintenance tools from the equipment before it is operated.
  • Keep the work area clean and clutter-free to prevent accidents.
  • Keep the equipment clean for the best performance.
Do not operate the equipment in a dangerous environment
  • Do not use the equipment in or around flammable gases or liquids.
  • Do not expose the equipment to rain or use it outdoors.
  • Keep the equipment in a bright work area.
Never leave the equipment unattended during operation
  • Always stop and turn off the equipment before leaving the area.
  • Keep visitors at a safe distance from the work area.
  • Keep children away from the equipment work area.
  • Do not let children play around or operate the equipment or its components.
Never operate the equipment without safety guards or covers
  • Do not change, bypass, or try to defeat the safety guards, covers, or switches.
  • Keep the guards in position and in working order.
  • Do not remove the safety cover or guard during operation.
  • Know the location of the ON/OFF switch.
  • Know how to disconnect the primary power supply to the equipment.
  • Start and operate the machine only when all side panels are in position.
Never put your hands in the area of the nozzle during operation
  • Seek immediate medical aid for all waterjet injuries. Injuries caused by high-pressure abrasive waterjets are serious. Do not wait!
  • Refer to the WaterJet Technology Association (WJTA) warning card for important medical aid information.
Figure 949
Be careful when material(s) is moved in the catcher tank
  • Do not operate the equipment when material is moved into the catcher tank.
  • Always stop the abrasive waterjet before adjustments are made to the material or the abrasive jet.
  • Always be careful when material is moved into the catcher tank. Fingers can be caught between a heavy part and the support slats.
  • Be careful around the support slats. The abrasive waterjet also cuts the support slats; the edges can become sharp and cause cuts or collapse.
  • Always use a licensed electrician or approved person to install the primary power source to use with the machine.
  • Examine the equipment power and control cables regularly for correct connection and installation. Damaged, exposed, and bare wires can cause electrocution or death!
  • Make sure the equipment is correctly connected and grounded in accordance with the national, state, and local codes. Do not remove the prongs from the plug. Always plug into the correct electrical outlet.
  • Never use any electrical plug adapter.
  • Make sure the power switch is in the OFF position before the equipment is plugged in to stop accidental starts.
  • Always disconnect the equipment from the primary power before service or maintenance work is done.
Noise Emission Precautions
Environmental factors, such as how the room or structure is built, other machines and power tools in the area, and other noise sources, can have an effect on the environment's true noise level. When installed and operated correctly, the equipment's A-weighted emission sound pressure level, LpA , is less than 75 dBA (LpA < 75 dBA). Therefore, OMAX recommends that the operator wear hearing protection during equipment operation.
Injuries that involve contact with the catcher tank water should receive medical aid immediately. Refer to the WJTA Warning Card for important medical aid information.
Get medical aid immediately for an abrasive waterjet injury. Tell the physician the cause of the injury, the type of abrasive waterjet work that was done when the accident happened, and the water source.
Stagnant water in the catcher tank can introduce dangerous bacteria into cuts, scrapes, small breaks in the skin, and other types of wounds. Injuries that involve contact with the catcher tank water should receive aid immediately. Injuries that involve contact with the water should be attended to immediately.
Unusual infections with aerophilic microorganisms that occur at lower temperatures have been reported. These can be gram-negative pathogens, such as those found in sewage. Bacterial swabs and blood cultures may be helpful to assist a physician's diagnosis.
An injury caused by high-pressure waterjets can be dangerous. If there is a waterjet injury:
  • Get medical aid immediately. Do not wait!
  • Tell the physician of the cause of the injury.
  • Tell the physician about the type of abrasive waterjet work done when the accident happened and the water source.
  • Give this information to medical personnel:
    This patient may be suffering from a waterjet injury. Evaluation and management should parallel that of a gunshot injury. The external manifestations of the injury cannot be used to predict the extent of internal damage. Initial management should include stabilization and a thorough neurovascular examination. X-rays can be used to assess subcutaneous air and foreign bodies distant from the site of injury. Injuries to the extremities can involve extensive nerve, muscle, vessel damage, and cause a distal compartment syndrome. Injuries to the torso can involve internal organ damage. Surgical consultation should be obtained. Aggressive irrigation and debridement is recommended. Surgical decompression and exploration may also be necessary. Angiographic studies are recommended pre-operatively if arterial injury is suspected. Bandages with a hygroscopic solution (MgSO4) and hyperbaric oxygen treatment have been used as adjunctive therapy to decrease pain, edema, and subcutaneous emphysema. Unusual infections with uncommon organisms in immunocompetent patients have been seen; the source of the water is important in deciding on initial, empiric antibiotic treatment, and broad-spectrum intravenous antibiotics should be administered. Cultures should be obtained.
Lockout/Tagout
Do standard practices and procedures to shutdown and stop the equipment, isolate it from its energy source(s), and prevent the release of potentially dangerous energy when maintenance and service work is done.
  • Make sure the equipment is correctly grounded in accordance with the national, state, and local codes. Do not remove the prongs from the plug. Always plug into the correct electrical outlet.
  • The ground wire gives the electric current a path of least resistance to reduce the risk of electrical shock during a malfunction or breakdown. The machine has an electric cord with an equipment-grounding conductor (EGC) and a ground plug (United States, Canada, and Mexico only). The plug must be connected to a matching outlet that is correctly installed and grounded in accordance with all local codes and ordinances.
  • Do not change the plug—if it does not fit the outlet, have the correct outlet installed by a qualified electrician.
  • If the EGC is incorrectly connected, it can result in electric shock.
  • Contact a qualified electrician or service personnel if the grounding instructions are not understood or if not sure if the equipment is correctly grounded.
  • Do not use extension cords with the equipment.
  • If the cord is damaged or worn, immediately replace it. Contact OMAX for replacement parts and instructions. The insulation of the EGC is covered with a green or green with yellow-striped surface. If replacement of the electric cord or plug is necessary, do not connect the equipment-grounding conductor to a live terminal. Refer to the equipment-specific wiring configuration.
  • The equipment is intended to be used on a circuit with an outlet similar to the one shown (United States, Canada, and Mexico only):
Figure 950
  • The grounding plug is similar to the one shown (United States, Canada and Mexico only):
Figure 951
  • Make sure that the equipment is connected to an outlet that matches the plug configuration.
  • The equipment must not be connected to any different type of electric circuit.
  • No adapter is available or should be used with this equipment.
  • For countries other than the United States, Canada, and Mexico, OMAX does not supply a sufficiently rated industrial-grade plug.
  • Contact a qualified electrician or service personnel to install a sufficiently rated industrial-grade plug in accordance with national, state, and local codes.
  • A pin and sleeve plug, rated at least 30A, 230V, 2-pole+E (3-wire grounding), IP44 or better, having a first-make last-break protective bonding contact (earthing contact) in accordance with standards IEC 60309-1 and IEC60309-2 can fulfill this requirement.
Figure 952
  • The cord must be plugged into a matching outlet that is correctly installed and grounded in accordance with all local codes and ordinances.
Figure 953
Machining certain types of material, such as titanium, with a waterjet can cause sparks. Do not operate the equipment in an explosive environment. Do not let explosive or flammable vapors collect in the area of the equipment.
Removal of Waste Materials
Discard all machining wastes correctly in accordance with all local and federal regulations. Abrasive waterjet machining causes two types of waste: the water used for machining and the solid material that collects in the catcher tank. Although the used garnet abrasive is not dangerous, the waste deposited from the cut material can require special treatment.
Sufficient Shop Ventilation
Make sure there is good airflow in the work area to dissipate gases, vapors, and fumes. The machine contains a large amount of water. The ambient temperature in the shop and of the water can have an effect on water evaporation. To decrease the effect on other equipment in the shop, make sure there is good airflow in the shop. Also, some materials, such as aluminum particles, are known to make hydrogen in water.
When aluminum is cut, the small particles of aluminum dust in the catcher tank react with the water to make flammable hydrogen gases. Usually, hydrogen bubbles to the surface and is released into the shop in safe, low concentrations.
Make sure no ignition sources (open flame or electrostatic discharge) are near the abrasive waterjet system.
Monitor the catcher tank for hydrogen gas bubbles when large quantities of aluminum are cut. The aluminum powder (made from the removed material) and spent garnet collect at the bottom of the catcher tank. The aluminum then reacts with the water and releases hydrogen gas. The hydrogen gas can collect in bubbles in the garnet. The hydrogen gas bubbles are flammable. Keep the garnet levels in the catcher tank low to prevent hydrogen gas bubbles from being collected within the garnet.
Do not smoke near the machine. Keep other sources of ignition or flammable materials near the machine. Be careful when materials that create sparks are cut, such as titanium, which can fire the gases in the catcher tank and cause an explosion. Remove the aluminum powder from the catcher tank before machining materials that spark.
Equipment Safety Features
The abrasive waterjet has several built-in safety features:
Overpressure Protection
During operation, pump pressure is monitored to prevent an overpressure condition. If the pump pressure increases more than the factory-set maximum pressure limit, the safety relief valve starts and stops the pump.
Electrical Protection
An electrical disconnect/emergency machine off (EMO) switch is used to remove the primary AC electrical supply from the machine. To isolate the machine from its electrical supply, always unplug the primary AC supply power cord from its electrical supply outlet.
Safety Lid
The lid of the equipment has a safety interlock to prevent waterjet operation when the lid is open.
Safety Legend
WARNING
CAUTION
NOTICE
Note
REQUIRED TOOLS
The following table contains a list of tools with the appropriate sizes needed to prepare the equipment for storage.
Customer Tools
These tools are not provided by OMAX or included with the equipment.
Icon Tool Size(s)
Open-end wrench 5/8 in., 19 mm
Ultrasonic cleaner
P/N 209476
Clean, dry, compressed air
Ball-end hex wrench 4 mm
Water spray nozzle
Shop towels
Torque wrench 25 in-lb (3 N•m)
Hex socket driver 4 mm
Desiccants, activated, type 2
P/N 200836
Flat screwdriver
Bucket
OMAX Tools
The following table contains a list of tools provided by OMAX. These tools are included with the equipment.
Icon Tool Size(s)
Seal removal tool
P/N 316852
REFERENCES
Documents
The following table contains documents associated with these instructions. Documents are located in KnowledgeBase Resources at knowledgebase.omax.com.
Part Number Title
401420 Installation, ProtoMAX
401434 Operation, ProtoMAX
401440 Maintenance, ProtoMAX
401527 Drain Water Filter Tank, ProtoMAX
401657 Drain Water Filter Tank, ProtoMAX, CE
Videos
Videos associated with these instructions are located in KnowledgeBase Videos at knowledgebase.omax.com.
DOCUMENT SCOPE
This document contains the procedures for preparing the ProtoMAX for storage longer than one month.
OVERVIEW
OMAX recommends specific procedures for the ProtoMAX when storing the machine for longer than one month during school breaks, vacations, and idle time. Follow the procedures to prevent abrasive from hardening inside the machine, high-pressure tube failure, and other damage.
STORING ProtoMAX FOR LONGER THAN ONE MONTH
1. Follow the shutdown procedure (see 401434 Operation, ProtoMAX and the ProtoMAX Shutdown video, located at knowledgebase.omax.com ).
2. Follow the Clean the ProtoMAX procedure (see 401440 Maintenance, ProtoMAX and see knowledgebase.omax.com, search for "clean"). Continue with the instructions.
The results from searching “clean” include the following primary tasks to clean the ProtoMAX.
Drain the Water Filter Tank
Drain the water filter tank (See 401527 Drain Water Filter Tank, ProtoMAXand the Clean the Drain Water Filter Tank video or401657 Drain Water Filter Tank, ProtoMAX, CE. and the Drain Water Filter Tank CE Guide video, located at knowledgebase.omax.com).
Figure 954
Store the Nozzle
1. Disconnect the abrasive feed tube from the nozzle assembly.
2. Remove the nozzle assembly [2] from the inlet body [1].
Figure 955
3. Remove the last chance filter and discard.
NOTE
The last chance filter is a consumable item and must be replaced when reactivating the ProtoMAX .
Figure 956
4. Remove the mixing tube [2] and orifice [3] from the nozzle body [1].
Figure 957
5. Clean the nozzle body, mixing tube and orifice with white vinegar using an ultrasonic cleaner.
6. Use clean, dry, compressed air to blow out the remaining moisture from the nozzle components.
7. Store the nozzle components in a closed drawer/tool box to prevent contamination.
8. Plug the end of the inlet body [1] with a plastic cap or plastic bag.
Figure 958
Clean Table and Rear Components
1. Remove the screws and washers [1] securing the rear lid and set aside.
Figure 959
2. Lift the rear lid up, then slide it down the high-pressure plumbing to the floor.
NOTE
To prevent scratches to the lid, place it on a soft surface.
Figure 960
3. Rinse off accumulated abrasive and other particles from the components and table inside the ProtoMAX.
NOTICE
Avoid spraying the black X and Y motor covers. Use a damp microfiber cloth to wipe off the motor covers. Spraying the motor covers with water may cause leakage into the motor housing which could lead to premature wear of the motor housing and cable connections
4. Reattach the rear lid and secure with the screws and washers (x 4).
NOTICE
To prevent damage to the lid [3], ensure the rubber washer [2] is placed between the lid and the metal washer [1]. Do not overtighten the screw.
Figure 961
5. After cleaning the catcher tank and interior components, use a wet/dry vacuum to remove remaining water. Leave the water drained.
6. Place humidity absorbing (desiccant) packs in the tank.
NOTE
Use sufficient number of packs for an approximate 11 cubic feet of enclosed tank and lid area (2 bags).
Clean the Hopper
1. Disconnect the abrasive feed tube [1] from the abrasive orifice. Leave it hanging from the roll bar.
Figure 962
2. Use clean, dry, compressed air to blow abrasive out of the abrasive feed tube.
3. Remove the hopper splash guard.
Figure 963
4. Remove the hopper ground strap [1].
Figure 964
5. Remove the hopper assembly [1] including the hopper feed block [2] from the hopper support plate [3].
Figure 965
6. Completely empty and discard the abrasive from the hopper assembly.
7. Remove the abrasive feed block [1] from the hopper assembly.
Figure 966
8. Wipe out the hopper assembly with a clean, dry cloth.
9. Use clean, dry, compressed air to completely blow out all debris, clumps, or clogs from the abrasive feed block.
Remove Water
NOTE
Remove the water from the system if the ProtoMAX is inactive for more than a few months (summer or semester break) and/or over a winter break where there is any chance of temperatures below 32 °F (0 °C).
Remove the Water Filter
See 401440 Maintenance, ProtoMAX, and the Change the Water Filter video, located at knowledgebase.omax.com.
NOTE
Discard the used water filter and replace with a new filter when taking the system out of storage. Remove all water from the filter canister.
Blow Out Water from the Low-Pressure Manifold
1. Loosen the band clamp [1] from the hose on the incoming water supply and remove the hose.
Figure 967
2. Disconnect the hose [2] (Figure 967) from the solenoid valve and put the loose hose end in a bucket.
3. Blow clean, dry, compressed air into the manifold inlet [1] and blow water through the plumbing and into the bucket.
Figure 968
4. Reconnect the hose to the incoming water supply (Figure 967).
5. Reconnect the hose to the solenoid valve(Figure 967).
Blow Water Out of the Pump
1. Disconnect the high-pressure components (see 401440 Maintenance, ProtoMAX and the Prepare the Pump for Maintenance video, located at knowledgebase.omax.com).
2. Use clean, dry, low pressure (45 psi) compressed air to blow out cooling water at port [1].
NOTICE
Do not exceed 45 psi when blowing out air from this port. Using air pressure higher than 45 psi may dislodge interior seals and O-rings.
Figure 969
3. Use clean, dry, high pressure (90 psi or more) compressed air to blow out water at port [2] (Figure 969).
Install Caps
NOTICE
It is very important to cap all openings. Uncovered openings may allow contaminants into the system. No ports or hoses should be left uncapped.
Install caps or block the openings on all hoses, tubing, and ports that are exposed to the environment (Figure 970) and (Figure 971).
Figure 970
[1] Outlet cooling port [2] Outlet cooling hose
[3] High-pressure tubing
[4] High-pressure port
Figure 971
[1] Incoming water port [2] Incoming water hose
[3] Inlet cooling port
[4] Inlet cooling tubing
Reactivate the ProtoMAX Machine
Follow the ProtoMAX install and start-up procedures to reactivate the machine (see 401420 Installation, ProtoMAXand the Install the ProtoMAX video, and 401434 Operation, ProtoMAX and the ProtoMAX Startup video, located at knowledgebase.omax.com).
Technical Support
Refer to omax.com for technical support information.
