Safety
This section contains important safety information for the equipment. Careful compliance with the safety information helps prevent physical injury, damage to the equipment, and can extend the equipment life.
Equipment Labels
These safety labels can appear on the equipment. If ignored, physical injury, death, or equipment damage can occur. Read the safety information in the equipment operation guides before the equipment is installed, operated, or maintained.
WARNING Electrical Shock
Electrostatic Discharge
WARNING Pinch Risk
Do not put hands or fingers near the nozzle during operation. Immediately get medical aid for waterjet injuries. Injuries caused by high-pressure abrasive waterjet systems are dangerous. Do not wait to get medical aid!
WARNING Flying Debris/Loud Noise
Eye and ear protection are required during operation. Removing the abrasive feed tube from the nozzle while under pressure will blow abrasive particles into the air, getting into eyes, and could contaminate tools and machines.
Do Not Spray
Wear Eye Protection
Wear Hearing Protection
Wear Gloves
Read Manual
Do Not Step
Removal of Waste Materials
Discard all machining waste(s) correctly and in accordance with local and federal regulations. Abrasive waterjet machining causes two types of waste: the water used for machining and the solid material that collects in the catcher tank. Although the used garnet abrasive is not dangerous, the waste deposited from the cut material can require special treatment.
Safety Legend
