ProtoMAX®
Laptop Tray Guide
Hypertherm, Inc.
21409 72nd Avenue South
Kent, WA USA 98032
Information:
Technical Support:
E-Mail:
Web:
This document contains subject matter to which Hypertherm, Inc. has proprietary rights. Recipients of this document shall not duplicate, use, or disclose information contained herein, in whole or in part, for any use other than the purpose for which this manual was provided.
OMAX Technical Publications
Kent, WA, USA 98032
Hypertherm, Inc. is continually improving their equipment to bring you the best in abrasive waterjet machining technology. For that reason, your abrasive waterjet may differ slightly from what is described in this document. If you have any questions, please feel free to contact us at 1-800-298-4036 or e-mail us at info@protomax.com. You can also receive technical support on-line at: Web: www.omax.com/protomax-waterjet.
June 2018
© 2018 Hypertherm, Inc.
Machine Safety Labels
WARNING Electrical Shock
WARNING Airborne Debris
WARNING Pinch Risk
Electrostatic Discharge
No Open Flame
Do Not Spray
Do Not Step
Read Manual
Wear Hearing Protection
Wear Eye Protection
Wear Gloves
Safety Legend
The following safety signal word panels and paragraph notifications may appear throughout this and other documentation. Each provides safety issue identification and recommended actions to avoid the hazard. Be alert! Follow the recommended safety actions and precautions to prevent injury or damage to the equipment.
WARNING
Indicates a hazardous situation which, if not avoided, could result in death or serious injury.
CAUTION
Indicates a hazardous situation which, if not avoided, could result in minor or moderate injury.
NOTICE
Used to address practices not related to physical injury—property damage only.
NOTE
Used to provide supplementary information, emphasize a point or give a tip for easier operation.
Required Tools
The following table contains a list of tools with the appropriate sizes that are needed to install the laptop tray onto the ProtoMAX. Tools listed with part numbers are included with the ProtoMAX or are available for purchase. Contact technical support for more information.
Icon Tool Size(s)
Spray bottle
Scrub brush
Allen wrench 4 mm, 3 mm
Shop rags
Safety glasses
Stand-off tool
P/N 317876
Overview
The laptop tray provides a stable platform to place the ProtoMAX laptop. It is easily assembled and installed on the ProtoMAX. This guides provides the instructions for assembling the laptop tray and installing it onto the side of the ProtoMAX.
Components
Figure 1
[1] Laptop tray [3] Cone point setscrew (x 2) [5] Front support bracket [7] Beaded chain
[2] Flat-head screws (x 4) [4] Flat point setscrew (x 2) [6] Rear support bracket
Assemble and Install the Laptop Tray
1. Remove the flat-head screws [1] from the brackets and set aside.
Figure 2
2. Loosen the four set screws [1].
note
Ensure the cone point setscrews are installed on top and the flat point setscrews are at the bottom.
Figure 3
3. Attach the brackets to the tray with the flat-head screws and tighten.
note
Ensure the thick bracket [2] is attached on the curved edge (front) [1] of the tray.
Figure 4
4. Hang the laptop tray on the left side of the catcher tank.
note
Ensure the rear of the laptop tray does not interfere with the hopper.
Figure 5
5. Adjust the set screws to stabilize the laptop tray against the catcher tank.
note
Tighten the top set screws until the pointed end of the screw sets firmly into the catcher tank. This helps the laptop tray from accident being knocked from the machine.
Figure 6
6. Place the laptop on the tray and route the laptop power cable [1] and USB cable [2] through the slots at the rear of the laptop tray.
Figure 7
7. Attach the bead chain to the stand-off tool (included with the ProtoMAX) and hang it on the laptop tray front.
Figure 8
Clean the Laptop Tray
The laptop tray does not require maintenance. Periodically cleaning the laptop tray of accumulated garnet is recommended and should be performed during normal cleaning activities.
notice
To avoid damage, do not use flammable liquids or other chemicals to clean the equipment.
1. Unplug the laptop power and USB cables from the laptop.
note
Do not allow these cables to fall to the floor where they can be stepped on and covered with garnet and other contaminates.
2. Place the power and USB cables in the slots provided in the laptop tray to hold them in place during tray cleaning.
Figure 9
3. Remove the laptop from the laptop tray and set it in a safe place during cleaning.
4. Wipe down the laptop tray to remove debris and garnet.
5. Place the laptop back in the laptop tray and reconnect the power and USB cables.
Technical Support
Refer to the ProtoMAX website for technical support contact information.
Warranty
Contact Customer Support or go to the ProtoMAX website.
