ProtoMAX®
Water Spray Nozzle Guide
Install the Water Spray Down Kit
Hypertherm, Inc.
21409 72nd Avenue South
Kent, WA USA 98032
Information:
Technical Support:
E-Mail:
Web:
This document contains subject matter to which Hypertherm, Inc. has proprietary rights. Recipients of this document shall not duplicate, use, or disclose information contained herein, in whole or in part, for any use other than the purpose for which this manual was provided.
OMAX Technical Publications
Kent, WA, USA 98032
Hypertherm, Inc. is continually improving their equipment to bring you the best in abrasive waterjet machining technology. For that reason, your abrasive waterjet may differ slightly from what is described in this document. If you have any questions, please feel free to contact us at 1-800-298-4036 or e-mail us at info@protomax.com. You can also receive technical support on-line at: Web: http://www.omax.com/protomax-waterjet.
June 2018
© 2018 Hypertherm, Inc.
Machine Safety Labels
WARNING Electrical Shock
WARNING Airborne Debris
WARNING Pinch Risk
Electrostatic Discharge
No Open Flame
Do Not Spray
Do Not Step
Read Manual
Wear Hearing Protection
Wear Eye Protection
Wear Gloves
Safety Legend
WARNING
CAUTION
NOTICE
Note
Overview
The water spray nozzle provides a convenient and easy method for washing parts of accumulated garnet and other areas of the catcher tank. A storage bracket is mounted on the side of the ProtoMAX for easy retrieval and storage of the spray nozzle.
Figure 1
[1] Thread sealant [3] Spray nozzle assembly with hose [5] Hose clamp
[2] Mounting bracket [4] Barbed elbow
Required Tools
The following table contains a list of tools with the appropriate sizes that are needed to install the water spray nozzle onto the ProtoMAX. Tools listed with part numbers are included with the ProtoMAX or are available for purchase. Contact technical support for more information
Icon Tool Size(s)
Safety glasses
Scrub brush
Socket 10 mm
Allen wrench 4 mm, 6 mm
Shop rags
Long handled spiral brush
Pipe sealant
(P/N 205669)
0.2 oz
Open-end wrench 12 mm
Flat screw driver
Preparation
Shut down the machine.
1. Turn OFF the water supply.
2. Lift and lock the lid in the open position.
caution
3. Remove any debris or accumulated garnet from the right side of the lid roll bar [1].
Figure 2
caution
Use care when working around the lid support. The lid may fall and cause injuries.
Install the Mounting Bracket
1. Loosen the two screws [1] on the right side of the lid roll bar.
Figure 3
2. Slide the mounting bracket between the washers [1].
Figure 4
3. Tighten the screws [1].
Figure 5
Install the Spray Nozzle Hose Assembly
1. Remove right side panel and set aside.
caution
Hose clamp must be loosened and rotated aside to avoid knuckle contact when removing the plug. Tighten when finished.
2. Remove the plug [1] from the water manifold.
Figure 6
3. Clean the port [1] to remove the old pipe sealant from the threads.
Figure 7
4. Apply a light bead of pipe sealant [1] beyond the second thread (away from the port) and completely around the barbed elbow.
note
The pipe sealant is distributed across all threads as the barbed elbow is installed on the manifold. Wipe any excess sealant from the manifold.
Figure 8
5. Install the barbed elbow in the manifold and tighten, making sure the barbed tip is facing downward.
notice
Do not tighten on the barbed tip. This will damage the barbs.
Figure 9
6. Route the hose under the frame, through the access port [1] of the catcher tank support plate to the manifold.
Figure 10
7. Loosen the hose clamp and slide the hose [1] completely onto the barbed elbow.
caution
Use care when attaching the hose; hose clamps have sharp edges that can injure.
8. Slide the hose clamp [1] half-way up the barbed nipple and tighten.
note
Do not over tighten the hose clamp. Over tightening the hose clamp may damage the hose, causing leaks.
Figure 11
9. Secure the hose along the inside of the frame with the cable ties.
notice
The water hose can rub and chafe the transducer cable and weaken or damage the connection. Always secure the water hose to keep it from rubbing against the transducer cable, and ensure the water hose does not pinch or trap other cables against the frame.
Figure 12
10. Store the spray nozzle in the mounting bracket.
Figure 13
11. Turn ON the supply water and check for leaks at the manifold and spray nozzle, adjust or fix as needed.
12. Adjust the spray nozzle water flow as needed.
13. Reinstall the right side panel removed in step #1.
Technical Support
Refer to the ProtoMAX website for technical support contact information.
Warranty
Contact Customer Support or go to the ProtoMAX website.
