IMPORTANT SAFETY INFORMATION
SAFETY IS YOUR RESPONSIBILITY.
For your own safety, read this guide thoroughly and carefully before installing, operating, maintaining, or troubleshooting the equipment.
Save these instructions.
This guide contains important safety information for the equipment. Careful observance of the safety information will help prevent physical injury, damage to the equipment, and extend the equipment life.
Equipment safety features, safety glasses, hearing protection, and more can reduce potential injury. Exercise caution when installing, operating, and maintaining the equipment. Safety guards and features will not guarantee your safety if you are careless, inattentive, or use poor judgment. If it feels dangerous, do not try it.
YOU ARE RESPONSIBLE FOR YOUR SAFETY IN YOUR SHOP.
Machine Safety Labels
The following safety labels may appear on the equipment. If ignored, physical injury, death, or equipment damage may occur. Read the complete safety information provided in the operation, installation or maintenance guide before installing, operating, or maintaining the equipment.
WARNING Electrical Shock Hazard
This symbol indicates the presence of life-threatening voltages. Never access areas labeled as such without first taking appropriate safety precautions: locking out power, verifying no voltage is present on circuits prior to maintenance activities, etc.
WARNING Flying Debris/Loud Noise
Eye and ear protection are required during operation. Removing the abrasive feed tube from the nozzle while under pressure will blow abrasive particles into the air, getting into eyes, and could contaminate tools and machines.
WARNING Keep Fingers and Hands Away From Moving Parts!
Fingers and hands can be pinched or cut by a moving parts hazard whenever the table is powered. Keep hands and fingers out of the path of moving parts. Never reach into moving machinery.
WARNING Pinch Hazard
When closing the lid, keep your hands clear from the edge of the tank.
Never place your hands in the vicinity of the nozzle while cutting.
Seek immediate medical attention in the event of a waterjet injury. Injuries caused by high-pressure abrasive waterjets are serious. Do not delay!
Keep the motor guards in place at all times during operation. Keep hands way from belts and pulleys when performing maintenance.
Electrostatic Discharge
Attention! Observe precautions for handling electrostatic sensitive devices.
No Open Flame
Do not allow smoking near the machine. Do not operate the equipment in an explosive atmosphere. Take care that no ignition source (such as open flame or electrostatic discharge) is nearby the equipment. Do not store flammable materials near the equipment. Do not use equipment in or around flammable gases or liquids. Do not allow explosive or flammable vapors to accumulate in the area of the equipment. Proper ventilation in your work area will assist in dissipating the accumulation of gas, vapor, and fumes. Be especially careful when cutting materials that create sparks, such as titanium—these can ignite gases in the tank.
Do not operate machine with guards or panels removed.
Do Not Spray
Do not spray water on or near the machine electrical enclosure.
Step Hazard
Never step, stand or walk on the support slats. They are weakened with cutting and may collapse under your weight.
Never make adjustments to equipment prior to reading the manual. Special instructions may be required. Adjustments may cause injury or damage equipment.
To isolate the machine from its electrical supply, always unplug the main AC supply power cord from its electrical supply outlet.
Read Manual
Read the equipment operator's guide for specific operator instructions and additional safety requirements. Do not attempt to operate this machine until you have read and understand all safety precautions and operating instructions.
Wear Ear Protection
Always wear hearing protection while in the vicinity of the equipment. When cutting above water, noise levels can exceed 70 dBA.
Wear Eye Protection
Always wear approved safety glasses whenever cutting. Regular glasses do not provide sufficient eye protection! The garnet abrasive is not a chemical irritant, but if not quickly washed out, it can injure an eye just as any sand would. In addition, tank water could contain particles from the material or chemical irritants. Have an eyewash station located near the work area in the event abrasive spray splashes into your eyes.
Read the product labels and refer to product Safety Data Sheets (SDS) to identify properties and hazards of chemical products and materials referenced in this document. Handle in accordance with good industrial hygiene and safety practice. Use personal protective equipment as specified in the SDS.
Wear Gloves
Bacteria in the tank water can build up. A minor break in the skin can introduce harmful bacteria into a wound. Always wear protective gloves if you have cuts or open wounds on your hands. When setting up material for cutting, wear gloves that provide protection against sharp metal edges.
Safety Precautions
Safety instructions must be followed when installing, operating, or maintaining the equipment. If ignored, death or physical injury may result, or damage may occur to the equipment. Always observe applicable safety precautions when working with this equipment.
Use the equipment ONLY for its intended purpose.
  • Read the installation manual before setting up the equipment to learn about important installation and safety information.
  • Read the documentation for recommended accessories. The use of improper accessories may cause risk of injury to persons or damage to equipment.
  • Wear eye and ear protection. Always wear ISO-approved impact safety glasses.
  • Ensure the equipment is installed properly before startup.
  • Never stand on the equipment. Serious injury could occur if the machine tips or if you come in contact with the cutting tool.
Do not make modifications
  • Never make unauthorized modifications or alterations to the equipment or components.
  • Modification to the equipment may pose risk of physical injury to the operator and/or others and may cause damage to the equipment or other property. Modifications to the equipment will invalidate the warranty.
  • Do not modify, defeat, or bypass any equipment safety features.
Do not remove panels
  • Do not remove panels under normal conditions. Only remove them when required by maintenance or troubleshooting procedures.
Check for damaged parts
  • Before further use of the equipment, a guard or other part that is damaged should be carefully checked to determine that it will operate properly and perform its intended function–check for alignment of moving parts, binding of moving parts, breakage of parts, mounting, and any other conditions that may affect its operation. A guard or other part that is damaged should be properly replaced.
Exercise caution, stay alert and attentive
  • Do not install, operate, or service the equipment while under the influence of alcohol or drugs. Read the warning labels on prescription and over the counter drugs. If in doubt, do not install or operate the machine.
  • Do not install, operate, or service the equipment when you are tired.
  • Always observe the safety precautions while installing, operating, or servicing the equipment. Carefully operated, the abrasive waterjet is a safe tool. When operated carelessly, serious injury can result.
  • Wear a face or dust mask.
  • Do not overreach to operate the machine. Maintain proper footing and balance at all times.
  • Keep a minimum of 16 in. (40 cm) away from pressurized equipment during operation.
  • Do not try to tighten ultra-high pressure (UHP) fittings while the system is under pressure.
Maintain tools and equipment with care
  • Keep machine and accessories clean for best and safest performance.
  • Always maintain the equipment in top condition.
  • Follow the maintenance instructions for equipment and accessories.
  • Maintain all protective guards and shutdown devices.
Keep the equipment and surrounding area clean and free from clutter
  • Remove any installation, operation, or maintenance tools from the equipment before operating.
  • Keep the work area clean and clutter free to avoid accidents.
  • Keep the equipment clean for optimal performance.
Do not operate equipment in a dangerous environment
  • Do not use equipment in or around flammable gases or liquids.
  • Do not expose equipment to rain, or use outdoors.
  • Keep the equipment in a well-lit work area.
Never leave equipment unattended while operating
  • Always stop and turn off the equipment before leaving.
  • Keep visitors at a safe distance from the work area.
  • Keep children away from the equipment work area.
  • Do not allow children to play around or operate the equipment or any of its components.
Never operate equipment without safety guards or covers.
  • Do not modify, bypass, defeat, or render safety guards, covers, or switches inoperable.
  • Keep guards in place and in working order.
  • Never remove any safety cover or guard while the equipment is running.
  • Know the location of the ON/OFF switch.
  • Know how to disconnect the main power supply to the equipment.
  • Start and operate the machine only when all side panels are securely in place.
  • Seek immediate medical attention in the event of a waterjet injury. Injuries caused by high-pressure abrasive waterjets are serious. Do not delay!
  • See your WaterJet Technology Association (WJTA) warning card for important medical alert information.
Figure 700
Use care when handling material in the tank
  • Never operate the equipment while handling material in the tank.
  • Always stop the abrasive waterjet before making any adjustments to the material or the abrasive jet.
  • Always be careful when handling material in the tank. Fingers can be caught between a heavy part and the support slats.
  • Use caution around the support slats. Support slats are also cut by the abrasive waterjet; the edges can become very sharp and cause cuts, or collapse.
  • Always use a licensed electrician or qualified individual for installing the main power source for use of the machine.
  • Inspect the equipment power and control cables regularly for proper connection and installation. Damaged, exposed, and bare wires can cause electrocution or death!
  • Ensure the equipment is properly connected and grounded in accordance with national, state, and local codes. Never remove any prong from the plug. Always plug into a proper electrical outlet.
  • Never use any electrical plug adapter.
  • Reduce the risk of unintentional starting by ensuring the power switch is in OFF position before plugging in the equipment.
  • Always disconnect the equipment from the main power before performing service or maintenance.
Noise Emission Precautions
Environmental factors, such as room or building construction, machines or power tools, and other noise sources affect the environment's true noise level. When installed and operated properly, the equipment A-weighted emission sound pressure level, LpA , is less than 75 dBA (LpA < 75 dBA). Therefore, OMAX recommends that the operator wear hearing protection during equipment operation.
Injuries involving contact with the water should receive immediate attention. See the WJTA Warning Card for important medical alert information.
Seek immediate medical attention in the event of an abrasive waterjet injury. Inform the physician of the cause of the injury, what type of waterjet project was being performed at the time of the accident, and the source of the water.
Because of the stagnant water within the tank, even a seemingly minor break in the skin can introduce harmful bacteria into the wound. Any injury involving contact with the water should be attended to immediately.
Unusual infections with aerophilic microorganisms occurring at lower temperatures have been reported. These may be gram-negative pathogens, such as those found in sewage. Bacterial swabs and blood cultures may therefore be helpful in assisting a physician's diagnosis.
An injury caused by high-pressure waterjets can be serious. In the event of any waterjet injury:
  • Seek medical attention immediately. Do not delay!
  • Inform the doctor of the cause of the injury.
  • Tell the physician what type of waterjet project was being performed at the time of the accident and the source of the water.
  • Communicate the following information to the medical personnel:
    This patient may be suffering from a waterjet injury. Evaluation and management should parallel that of a gunshot injury. The external manifestations of the injury cannot be used to predict the extent of internal damage. Initial management should include stabilization and a thorough neurovascular examination. X-rays can be used to assess subcutaneous air and foreign bodies distant from the site of injury. Injuries to the extremities can involve extensive nerve, muscle, vessel damage, as well as cause a distal compartment syndrome. Injuries to the torso can involve internal organ damage. Surgical consultation should be obtained. Aggressive irrigation and debridement is recommended. Surgical decompression and exploration may also be necessary. Angiographic studies are recommended pre-operatively if arterial injury is suspected. Bandages with a hygroscopic solution (MgSO4) and hyperbaric oxygen treatment have been used as adjunctive therapy to decrease pain, edema, and subcutaneous emphysema. Unusual infections with uncommon organisms in immunocompetent patients have been seen; the source of the water is important in deciding on initial, empiric antibiotic treatment, and broad-spectrum intravenous antibiotics should be administered. Cultures should be obtained.
Lockout/Tagout
Implement standard practices and procedures to shut down equipment, isolate it from its energy source(s), and prevent the release of potentially hazardous energy while maintenance and servicing activities are being performed.
  • Ensure the equipment is properly grounded in accordance with national, state, and local codes. Never remove any prong from the plug. Always plug into a proper electrical outlet.
  • To reduce the risk of electric shock, during a malfunction or breakdown, grounding provides the electric current with a path of least resistance. The machine is equipped with an electric cord designed with an equipment-grounding conductor (EGC) and a grounding plug (United States, Canada and Mexico only). You must plug the cord into a matching outlet that is properly installed and grounded in accordance with all local codes and ordinances.
  • Do not modify the plug provided—if it does not fit the outlet, have the proper outlet installed by a qualified electrician.
  • Connecting the EGC improperly can result in electric shock.
  • Contact a qualified electrician or service personnel if you do not understand the grounding instructions, or if in doubt as to whether the equipment is properly grounded.
  • Do not use extension cords with the equipment.
  • If the cord is damaged or worn, immediately replace it. Contact OMAX for replacement parts and instructions for replacement. The insulation of the EGC is covered with a green or green with yellow-striped surface. If replacement of the electric cord or plug is necessary, do not connect the equipment-grounding conductor to a live terminal. Refer to the equipment-specific wiring configuration.
  • The equipment is intended to be used on a circuit with an outlet similar to the one shown (United States, Canada and Mexico only):
Figure 701
  • The grounding plug is similar to the one shown (United States, Canada and Mexico only):
Figure 702
  • Ensure that the equipment is connected to an outlet that matches the plug configuration.
  • The equipment must not be connected to any different type of electric circuit.
  • No adapter is available, or should be used with this equipment.
  • For countries other than United States, Canada and Mexico; OMAX does not supply a suitably rated industrial grade plug.
  • Contact a qualified electrician or service personnel for installation of a suitably rated industrial grade plug in accordance with national, state, and local codes.
  • A pin and sleeve plug, rated at least 30A, 230V, 2-pole+E (3-wire grounding), IP44 or better, having a first-make last-break protective bonding contact (earthing contact) in accordance to standards IEC 60309-1 and IEC60309-2 may fulfill this requirement.
Figure 703
  • You must plug the cord into a matching outlet that is properly installed and grounded in accordance with all local codes and ordinances.
Figure 704
Machining certain types of material such as titanium with a waterjet may produce sparks. Do not operate the equipment in an explosive atmosphere. Do not allow explosive or flammable vapors to accumulate in the area of the equipment.
Disposing of Waste Materials
Dispose of cutting wastes properly and in accordance with all local and federal regulations. The abrasive waterjet produces two types of waste: the water used for cutting and the solid material that accumulates in the catcher tank. Although the garnet abrasive itself is inert, the waste deposited from the material being cut may require special handling.
In abrasive waterjet cutting, garnet particles are accelerated with high-pressure water to strike the material creating a residue of abrasive grit and eroded particles from the cut material. Eventually, this residual sludge settles to the catcher tank bottom and accumulates until it must be removed for disposal. Depending upon the material makeup of this sludge, different disposal constraints will be imposed by the various local and federal regulations. For example, when cutting toxic materials, such as lead or radioactive metals, appropriate measures for the safe disposal of this type of contaminated water and sludge must be rigidly followed. Always consult with your local utilities company about sewage or water treatment requirements and proper sludge disposal procedures.
Adequate Shop Ventilation
Proper ventilation in your work area will assist in dissipating the accumulation of gas, vapor, and fumes. Your machine contains water that will evaporate depending on the ambient temperature in your shop and the temperature of the water in the tank itself. In order to reduce impact on other equipment in your shop, you should maintain adequate ventilation in your shop. Additionally some materials (especially aluminum particles) in water are known to produce hydrogen in water.
When you cut aluminum, the fine particles in the tank react with the water to generate hydrogen. Normally, hydrogen bubbles to the surface and escapes into the shop in harmless, low concentrations.
Watch for hydrogen bubbles when machining aluminum. If you cut a lot of aluminum, you will create aluminum powder from the removed material. This powder will accumulate at the bottom of the tank along with your garnet. The aluminum then reacts with the water, releasing Hydrogen gas in the process. If you cut a lot of aluminum on a regular basis, then this is something to take into consideration.
Do not allow smoking near the machine. Take care that no ignition source (such as open flame or electrostatic discharge) is nearby the equipment. Do not store flammable materials near the equipment. Be especially careful when cutting materials that create sparks, such as titanium—these can ignite gases in the tank.
Equipment Safety Features
The abrasive waterjet provides several built-in safety features:
Overpressure Protection
During operation, pump pressure is monitored to prevent an overpressure condition. If the pump exceeds the factory set maximum pressure limit, the safety relief valve activates and shuts down the pump unit.
Electrical Protection
An electrical disconnect/emergency machine off (EMO) switch is used to remove the main AC electrical supply from the machine. To isolate the machine from its electrical supply, always unplug the main AC supply power cord from its electrical supply outlet.
Safety Lid
The lid of the equipment is designed with a safety interlock to prevent waterjet operation when the lid is open.
Safety Legend
The following safety signal word panels and paragraph notifications may appear throughout this and other documentation. Each provides safety issue identification and recommended actions to avoid the hazard. Be alert! Follow the recommended safety actions and precautions to prevent injury or damage to the equipment.
WARNING
Indicates a hazardous situation which, if not avoided, could result in death or serious injury.
CAUTION
Indicates a hazardous situation which, if not avoided, could result in minor or moderate injury.
NOTICE
Used to address practices not related to physical injury—property damage only.
NOTE
Used to provide supplementary information, emphasize a point or give a tip for easier operation.
