Water Filter
The water filter removes debris from incoming water that can clog and damage the high-pressure components. The water filter is mounted on the side of the table assembly. The outlet water pressure is monitored by the pressure gauge mounted on the water filter.
Do not operate the ProtoMAX without the incoming water supply filter. Operating the ProtoMAX without the water supply filter will introduce debris into the system and may damage the pump and high-pressure system.
Figure 378
| [1] Water manifold | [4] Water control solenoid | [7] Water temperature transducer |
| [2] Air release button | [5] Water pressure switch | [8] Water connection (incoming) |
| [3] Water pressure gauge | [6] Water filter assembly |
