Tank Drain
The adjustable tank drain helps maintain optimal water level by allowing excess water to drain from the catcher tank during cutting operations. The drain has a flexible tube to adjust the water level as needed and allows cutting underwater. The tank overflow allows excess water to exit through the drain port and drain hose to prevent overfilling.
Figure 372
| [1] Adjustable tank drain | [2] Tank overflow drain | [3] Tank drain hose | [4] Tank drain port |
