Reset the Pump
The reset pump test runs a 30 second sequence to reset the pump. This test should be done before operating the ProtoMAX for the first time, after changing the nozzle orifice, repairing or replacing the pump, repairing any high pressure plumbing leaks, or when required by a fault or alert message.
| 2.
Move the nozzle between two slats. |
| 4.
In Test Operations, select Reset Pump, and click Next. |
| 5.
Click Start Test and check the high-pressure plumbing for leaks (the dialog box closes when the test is complete). |
