Install the Bottom Support Bracket and Side Panels
1. The bottom frame support bracket is in a package located behind the middle frame support bracket. To remove it, grasp it on the left side and carefully lift it diagonally from the frame.
NOTE
Always lift the bracket diagonally from the left end. The bracket cannot be removed by lifting straight up.
2. Remove all packing materials from the bottom frame support bracket.
3. Install the bottom frame support bracket [1] using the provided hardware.
Figure 268
4. Install the side panels:
a. Slide one end of the panel into the support leg slot.
NOTE
Support the bottom of the panel while inserting the edges into the frame support.
b. Press the other side of the panel down into the opposite support leg slot.
Figure 269
c. Press on the center of the panel to secure it to the table frame.
d. Repeat steps 1–3 for each panel.
The ProtoMAX installation is complete and ready for operation. Refer to the document, 401434 Operation, ProtoMAX.
